1995 Pro V 150 Lower unit [Need Desperately]
musky hunter
Hi guys can anyone steer me to a lower unit for my 1995 Pro V yamaha mine is screwed as per the marina, The only problem I live in Orillia Ontario Canada, I will take aused unit if it is mint or a rebuild or new... HELP HeLP
rodbolt
Re: 1995 Pro V 150 Lower unit [Need Desperately]
do you need a 20 or 25 inch unit.
musky hunter
Rodbolt here is the engine serial number as I dont know for sure P150 TLRT 6J9L 356170
rodbolt
its a 20 inch. 95 model<br /> t is trim l is long(20") R is remote and t is 1995 my 89 unit is a 25" and wont help ya. some of the rebuilders here in the states will redo it with a new case for about 1000 dollars us.<br /> good luck and keep posting
musky hunter
Thanks anyways Rodbolt the price here is $2600.00<br />canadian dollars for a rebuilt with warranty.<br /> The problem started when the marina I took it to can not remove the bearing casing to redo the prop shaft seals as it is so badly corroded by the saltwater that the guy I bought it from said that it never seen saltwater, they broke a puller tried heating the casing with a torch etc and this thing wont budge one bit any ideas??
Ray Neudecker
Try Bob Kottman at 636-338=4080. Best to call early. 7:30 am CDT or soon after. Keep in mind the customs fees when shipped by UPS to Canada. They may make you scream and say nasty words.
rodbolt
not really. I have actually pulled a bearing housing in half before. saltwater can weld it tight.<br /> sounds like its time to take a vacation to the states and buy one then go back :) :) heat and more heat. I use the J style puller legs from OMC. best tool ever for a yamaha.<br /><br /> good luck and keep posting
