Desert Rat
Thread starter- Joined
- Apr 12, 2004
- 22
Hi guys. Got my hands on a 2001 40hp EFI Suzuki. Gas is not making it to the injectors. The fuel comes in from the tank goes through a clear ?filter? then into the pump on the back of the motor then enters the engine on the left side of the motor. The fuel makes it this far ok and the pump is working fine. I disconnected the outlet hose from the pump and turned the engine over and plenty of gas sprayed out. However, no fuel is coming out of the left side and going to the injectors. Is this a computer problem? What is the aluminum box on the left side where the fuel goes into and comes out of? On the bottom of this aluminum box is a drain screw so you can drain sediment out. I opened it up and clean clear fuel came out. There is a black filter on the top left side of the motor right before the gas goes to the injectors and no gas is making it to this filter. Sorry for the long winded post. Thank you for your help.
