Similar posts have been made but still need help.<br />Yellow oil warning lite comes on although remote reservoir full. Computer thinks tank empty and does not pump oil to engine reservoir. With manual switch activated pump operates and fills engine tank. Engine then operates normally till this reservoir runs down, then cuts out as it goes into protection mode. Red lite comes on. Filters clean. Lines clean. Removed float assembly in remote tank and seems okay, although I can't figure out how that little styrofoam float works. Obviously pump works. Thanks<br />Laird
