Re: Second Yamaha 115 four stroke this year.
Thanks Rodbolt, I didn't realise the injectors cycled on shutdown. Is this a recent change to the ECU, our motors are 2002 model, 2001 manufacture. If the ECU dumps the pressure from the fuel rail on shut down how can puting a pressure gauge on the fuel rail tell you anything. I agree with you about restricting the fuel suction line but there are fine filters with extended surface area that have less pressure drop than the course filters - buy big and quality.
http://www.yamaha-motor.com/accessories/otb/fuel01.html sums it up well and is an admision that their EFI & DFI filtration is inadequate. Anyway this filtration is rz about face - fancy having filters getting courser as it gets closer to the critical parts. Take a look at an EFI car to see how it should be done. 35 microm before the mecahanical pump, 25 microm before the injector pump, 5 micron before the injectors. The 5 micron filter protects the injectors from the fine stuff that can effect the injector spray patterns and shut-off, catches wear particals from the injector pump and the little black bits that benzine and other lead subsitute fuel additives seem to disolve from the fuel system. The 5 micron filter is a pressure filter that costs about $NZ10-$20 (US$5-$10) This apears more money than Yamaha can afford to spend on their F115s but Honda seem to manage to afford the pressure filters. EFI Cars & EFI Honda outboards have them and don't have ("as many")fuel in oil problems. Yamaha doesn't have them and has a high incidence of fuel in oil problems (over 50 cases on the web I have found so far)<br />You ask how can the fuel leak into the engine if the rail pressure is blead off - well the same crude that effects the injectors effects the fuel pressure regular shut off which then vents to the VST tank. We have photos of the clean patches in the bores where the fuel has ponded before leaking past the pistons (engine stopped). We have done the sums - our last oil test had 3% fuel & 3% water, (from 15 hours running) thats 3% of 4.5 litres = 135 ml, the fuel rail hold 30 ml of fuel, thats like turning the motor off 5 times. You seem very experienced but keep an open mind and think about. <br />We have legislation that controls fuel octane, additives and everything else but not particulate levels. Our service stations have a mix of 50 micron strainers and 30 micron filters.
