Standard jets for c series 130
bonitoman
I am going to pick up some new jets for my 92 130 carbs. What # jets would I need for a c series 130. High low and intermed. Anyone know the #'s because the guy at my local dealership is clueless. Thanks
rodbolt
Re: Standard jets for c series 130
why do you need new jets and what jets are you replacing?<br />the jets are maked with a size. use the original size. your not going to gain HP with a jet change.<br /> good luck and keep posting<br />tell your parts guy to look on the micro-fiche
bonitoman
I rebuilt it this winter and I was talking to a friend of mine. Since I removed the oil injection and removed the pump and rod. I have been using premix. I bought a blank off plate and it has been a c series for about 70 hours. He suggested that the c series uses different jets so I am going to change mine to what a c series 130 would use.I don't know if it will help. The engine has been great except for one minor electrical problem.
rodbolt
carefully look up and compare all the jets. I dont think using a 2% oil mix is going to require any jet changes. if its running well and makes good power and idles well leave it be.<br /> good luck and keep posting
bonitoman
I am running at 50 to 1 oil mix. Where does 2 percecnt come from?
