Yamaha model number
Triton II
I have tried to get a workshop manual for my FT60BETL (2003 - the "high thrust" model) but yamaha.com only lists the F60TJRB and the F60TLRB. Is either of these the correct manual? Yamaha Aus are about as useful as a chocolate kettle hence my going to Yam USA.
superteddan
Re: Yamaha model number
Here is the breakdown of the US model codes,<br /> http://www.boats.net/cgi-local/listings.pl?type=info&stype=motor&id=14247 <br />And the Euro/Aussie equivalent,<br /> http://www.yamaha-motor.co.uk/products/marine/outboards/model_codes.jsp <br />One of your options that you had found, is obviously a Jet drive, which rules that out. The US equivalent of your motor, should be something along the lines of FT60TLRB. In your case I would suspect there are a few differences in build spec between the High Thrust and the "regular" model, obviously the prop setup, but in all essential details, you could be ok with your other suggestion. Or you might try the right model but 2004? It seems they have that one. Hope it helps.
Triton II
Thanks Superted, it looks like the model is called the T60B in the USA. However it seems Yam US won't ship to Aus from their website shop, so I'll have to order it through Yam Aus... at almost twice the price! If only we had our weather and USA prices... :rolleyes:
rodbolt
hello<br /> I can email ya the info. the main manual is the same as the f50,t50 z-a models. the supplemnts are the same as the f60a and t60b the main manual part # is lit-18616-02-33<br /> supplement f60a lit-18616-02-40, supplement t60b lit-18616-02-46
Triton II
Thanks rodbolt. Helpful as ever. I'm especially after the lower leg maintenance pages... still getting a tiny amount of water in the oil!<br />My email is: mdbarnett@optusnet.com.au.<br />Will I need the supplement 02-46?
rodbolt
I sent it<br /> I think my computer is possed. I am having problems getting my scanner to transfer pics to my email.
Triton II
Cheers rodbolt, got it loud and clear. You Sir, are a gentleman and a scholar!<br /><br />Mark.
