Re: Low Rpm's
Sharkba852, what Rodbolt is refering to by a "test wheel" is a tool. It doesnt tell you what the correct pitch is, but applies a known resistance to a given motor in the water. The motor will then, if running correctly, rev to a given rpm at wide open. That rpm may or may not be what youll set up for later. But it does tell you the motor is putting out what it should or not.<br /><br />If it doesnt reach the specified 5100-5300 then you look at a motor problem, not a prop or set up issue. You will need to verify the test with a shop tach. Again a tool thats a known good instrument.<br /><br />Who knows? Your tach could be set wrong. I would have thought that a 17 would zing that baby. <br /><br />Stick with Rodbolt, he'll get ya goin.
