Salty Feather
Thread starter- Joined
- Feb 18, 2005
- 9
I have a 2000 Yamana 150 HP 2 stroke. While running at different RPMs the engine drops in RPMs, the drop is only 100 to 200 rpm. This problem comes and goes. I have replaced the plugs,the water seperater filter and the inline fuel filter. The Dealer I use thinks it may be the carbs but has not had the engine at thier shop to confirm this.<br />This season I winterized the engine the same way I always do but noticed that when I fogged the carbs the engine did not hesitate at all when spraying the top or bottom carbs, but did when I srayed the center one. The engine was running at idle speed. Is this normal or is it telling me the other cylinders are not firing or something ?
