jay dezman
- Joined
- Sep 19, 2004
- 85
several months ago, you provided some input on my underperforming 200 hp suzuki. at last post, my season had ended and i said i would pursue your suggestions in spring. <br /><br />last sunday, i took the cover(cowl) off and checked the air gaps for the pulser coils on the underperforming engine. one coil's air gap was visibly larger than the other two. i know you said to set the gap to a minimum voltage reading.<br /><br />i presume a smaller gap = a higher voltage output. other than preventing physical interference, is there such a thing as "too small a gap"?<br /><br />i still haven't located a cd77 with which to test voltage. <br /><br />when acquired, is this test done with the engine running? cranking with the starter? or just manually rotating the magnet past the sensor?
