multifunction tach
nanoa
I just purchased a yamaha multifunction tach part # 6y5-8350t-82-00 included was engine and fuse harness I understand everything in the wiring except can not figure our where to hook the engine harness to my 2004 yamaha 115 please help i pulled the engine cover and cannot find connection point
rodbolt
Re: multifunction tach
if you have the trim harness,4wires pink, orange,gray, and black. and the two wire oil/alaem harnes, green and green red. and the tach harness that haas the fused yellow wire then its all plug and play. make sure the dip switches are set for two wire trim, 12 pole alt and 2 stroke. the rest is plug and play. but ya have to have 3 harness's. two from the engine to the tach and one from the keyswitch/contol box to tach. all engine connections are made beside the shift slide on the stbd side of the engine.
