oil tank overfilling
rbjam65
My 1988 yam 200 leaks oil out the overflow tube and into the air intake cover. I think it might be the float switch? Could it be the override switch is stuck on?
Ray Neudecker
Re: oil tank overfilling
Common cause on those models was the control module. First check to be sure the cap is on properly and the tank sensor is working correctly.
rbjam65
Hey thanks for the reply. I took the float switch off the other motor and it worked. So problem solved. :D
rbjam65
What manual would be best for this motor? L-200ETG
