Buckeye-Basser
Thread starter- Joined
- Feb 10, 2005
- 22
This just started happening without any warning. I try to put into forward gear and hear grinding and a lever used for shifting under the bottom carb pops off. Reverse works fine. Took lower unit off and pulled off the clutch. The clutch can be put into reverse and neutral, but it wont stay in forward, it just pops back up. My question is could the problem be in the clutch or is it probably the gears. Thought I would ask before I pulled the gears out. What else should I look for before I dig into this. Thanks, DAVE
