Key west Tom
- Joined
- Jun 5, 2005
- 32
On the topic of the oil injection on a 1988 Yamaha 150hp. I was wondering about the timming of the oil injection pump. Is it timmed? I understand you have said no it is not, but in my book (this is not a book from Yamaha it is a aftermarket book) that i'm using to put the motor back together it said to make sure that I put the oil hoses back in the correct order and to the correct port. If I must put the hoses to the correct port then the pump may be timmed, is this correct? or is the book misleading? Does the oil injection pump pump out pulses of oil or is it more of a steady flow? If it is pulses of oil than I would want that pulse of oil to shoot in at the same time as the flow of air and fuel so it will mix and not just puddle in the intake area, right? One more thing this motor has been compleetly taken apart, crank out and the oil pump drive gear out.<br /> Sorry about reasking this question over again but I just don't want to damage the motor, i'm helping a friend put his motor together.<br />Thanks again for the help,<br />Tom Kelly
