SctSimpson
- Joined
- Jun 17, 2005
- 5
I've got a '91 175HP Yamaha O/B with a Reserve Oil Tank on the boat. Right now the emergency switch on the engine will pump oil from the reserve tank (so the pump, and all oils lines are good), however the CDI Unit will no longer active the pump when the oil in the integral tank gets low, it will however sound the buzzer alarm when it gets too low.<br /><br />I've check all of the wiring for continuity (at least that I can think of), the oil level sensor in the integral tank registers on the gauges correctly (Green and Yellow as you move the sensor in and out of the tank), and I just replaced the sensor in the integral tank with no success.<br /><br />All of this started occuring just after I replaced the gauges in the boat, but I'm at a loss to figure out how that would effect the oil transfer (in fact I've put the old gauges back in and that did not resolve the problem).<br /><br />Any suggestions on why the engine (CDI) would stop sending the transfer pump a signal?<br /><br />(Sorry for the long post, wanted to be sure everyone had all of the info I know).<br /><br />Thanks,<br />Scott
