Re: Starter vs. ignition problem?
Ok JB, or whomever has advice, I am pretty sure it is the ignition switch but I would like to hear some thoughts because I just found out a new switch runs about $90. I have tested the solenoid (volt and ohm tests) shows no volts with key OFF, shows no volts in ON position, shows volts at START. When key is turned all the way back to OFF volts are gone, but if key is just released from START, volts remain. <br />When engine is started, the starter pinion gear drops from fly wheel but starter continues to spin. Sometimes fiddling with the key will cause the starter to stop. I checked the ignition wires at switch and am getting some abnormal readings(showing circuits between wrong wires).<br />Thanks again for all the help I appreciate it.
