Re: Prop size Yamaha 75
If you're in the rpm range you think you are (under 4000), you're too far off to use the 200 rpms/inch estimate. If I were in your situation I'd go with either a 13 or 15 pitch prop (knowing that you're current prop is too far off to make a good guess as to which is really correct), and order a tachometer at the same time. If it's a tiller, just go with a TinyTach and mount it next to the motor. The tach will then tell you whether you're propped right, or if you need another prop.<br /><br />Remember, once you've got it propped right for ferrying 8 surfers and boards, you'll be severely underpropped when you're running solo. You really need a tach for your setup.
