Originally posted by Booner:<br /> Welcome to iboats jdsg <br />Quote by jdsg<br />"We have tried adjusting the anode but have had no luck."<br /> Did you mean the trim tab? Turn the rear end of trim tab to the right (starboard side)
Originally posted by bluebird:<br /> As you get on plane trim out the motor until you get a more neutral steering response. When you get it high enough it will feel better.
That's it. That is the devise to counteract torque steer. <br /><br />They are called by many names - zinc, tab, little rudder thingy.........<br /><br />Turn the trailing edge ( the bit closest to the the rear) in the same direction of the pull, that will counteract the pull and should straighten you up. Sometimes it takes a few adjustments to get it right.<br /><br />AldoOriginally posted by jdsg:<br /> I may be calling it by the wrong name, but I assume it is a zinc at the bottom of the motor which has a small fin. I have no trim tabs (unless there is something on the engine). Thanks for the help
Originally posted by bluebird:<br /> The motor should be equipped with power trim actuated by a switch on the throttle/shift control. It says up down on it.
