edgutgesell
Thread starter- Joined
- Jul 18, 2004
- 144
A friend of mine has a 1989 150 hp V6 with an oil pump that has a bad check valve causing smoking when first starting up. The smoking is not caused by the main tank overfilling and overflowing into the carb airbox. This was determined by observing the oil level in the main tank while running.<br /><br />He ordered the "Oil Pump Conversion Kit" from Yamaha. The old oil pump is the type that has the oil hoses going to the engine configured in a circular pattern on top of the pump. The new conversion pump's outlets are three outlets on the left side of the pump and three outlets on the right side of the pump. The Yamaha installation instructions do not fully describe which outlets go to what cylinders. I did a search and found a topic "1989 225 excel yamaha retro oil pump", Author: jk1162, that almost answers my question. The last entry by jk1162 is as follows. There was no followup that indicated that the entry was correct! It read:<br /><br />RAY, I HAVE A 1989 225 WITH A RETROFIT NEW STYLE PUMP WHICH IS LIKE THE ONES BEING USED ON THE 1990 EXCEPT FOR THE DIRECTION IT TURNS. HENCE MY DELEMMA. I HAVE THE MANUAL FOR THE OLD STYLE FLAT TOP CIRCLE PUMP, BUT NOT THE NEW STYLE PUMP. LOOKING AT THE FRONT OF THE NEW STYLE PUMP WITH THE MAIN OIL FEED ON THE LEFT; BACK RIGHT IS IN THE MIDDLE #4, FRONT RIGHT TOP #1, & FRONT RIGHT BOTTOM #2, LEFT FRONT MIDDLE #5, LEFT BACK TOP #3,& LEFT BACK BOTTOM #6. I THINK THIS IS RIGHT BUT I REALLY DO NOT KNOW FOR SURE SINCE THE DIAGRAMS THAT CAME WITH THE RETROFIT PUMP SHOWS IT 2 DIFFERENT WAYS NEITHER OF WHICH IS AS I DESCRIBED. THEY SHOW DIAGRAMS OF THE TUBE ROUTING BUT NO DESIGNATION ON THE PUMP AS TO WHICH CYLINDER THE PORTS REALLY GO TO.
