What's it worth ? 1993 Yamaha 9.9 (4 stroke) long shaft
fishon71
Ball part what the above clean good running engine is worth?<br /><br />Yamaha 9.9 <br />1993<br />electric start<br />long shaft<br />large thrust prop<br />tiller
ST
Re: What's it worth ? 1993 Yamaha 9.9 (4 stroke) long shaft
I would think it's worth between $700 and $850 on that "good" condition. The Hi-thrust prop alone cost about $110.<br />My .02...Sam.
fishon71
Thanks, I need to get the big prop fixed its got a chunk out of it, should not be an issue right?
ST
You can have it repaired; I have noted that the shop below did a good job; (recommended from some members of another forum); repair cost started at $38 for an 11" aluminum prop diameter; here's the address:<br /><br /> http://www.midwestpropeller.com/ <br /><br />Good luck!
fishon71
ST,<br /><br />I can see how these large thrust props get damaged. There so big and protrude out it is hard to lift anf move engine around with out damaging it. It is super thin too. I took it off last night for a closer looks, its banged up pretty good.<br /><br />I'll give them a call, thanks
