Shifting Reverse Problem
RicardoR
I have a 272 1994 Regal with 2 I/O Yamaha 4.3 v6<br />and I can shift forward with out any problem , but when I try to shift reverse is to hard to do it and sometime is impossible. I change both Shift Cable from the engine to the out drive and nothing,,, the killing Swicth are working fine.<br /><br />I don't know what else to do, Please Help me !!!<br />Ricardo J Rosello
rodbolt
Re: Shifting Reverse Problem
this needs to move to the I/O section.<br /> but if the cut out switch and cables are fine its usually a worn fork in the shift mechanisim or a corroded busing on the upper shift shaft in the upper housing, they are a pain but need to be cleaned and greased occasionally
Capt Ken
Probably more like the shift slide is corroded and not sliding back over the cable in reverse smoothly. When you replace the lower cable, the slide needs to be bored out some to remove the corrosion. Also if you are not careful when reinstalling the drive, you can bend the end of the cable and it will produce the same problem.
RicardoR
I change the cable twice and is doing the same thing,I was just thinking in the possibility of the killing swicth is damage because when the engine are off you can change manually the shift cable but when I turn on the engine only go Forward and get really hard to shift from Forward to reverse.<br /><br /><br />Please Thank you to all for take the time to Help me out with this problem, I'm going crazy with this situation.
Capt Ken
Nuttin wrong with the switch, its doing what's its suppose to do. There is four parts to that shift system, cable, slide, shift arm and shift fork. Being you've changed the cable twice, then it must not be that. Being you are able to shift in forward and not reverse, tells me the shift fork and shift arm is moving and not frozen. That leaves the shift slide, take the drive off, remove the shift slide and remember the turn count on the nut, clean out the hole in the slide and reinstall.
Capt Ken
Wait I may be confused? Is it killing the engine when you shift into reverse or is it not coming out of forward until you kill the engine? If the engine isn't dieing when you shift, then it may be the switch not killing the ignition.
RicardoR
is it not coming out of forward until I kill the engine,and some time when I'm able to move the command to reverse, the boat still going forward.
