Re: 1992 Suzuki DT 40 Carbeurator
jjmd, good tip...sorry about the vagueness. So far as I know, he feels that the fuel delivery is working properly b/c after the engine dies, he has pulled the carb and there is still fuel in the float bowl. Also, he has pulled the plugs after the engine dies and states that they are dry. He did dump out some sediment from the fuel filter but does not seem believe that there is any sediment in the line after the filter. A little history here. First the engine was VERY difficult to start/idle. We replaced the manual choke lever (b/c it was broken and not working at all) and presto....the engine starts much easier and will stay cranked at idle (even in water which it would not do before????) However, once that small repair was made, the top end (higher RPM) running ability of the engine which functioned flawlessly before was now gone. So basically, if you gunned it or went to high RPM it would just die? He is absolutely certain that he has the adjustments set correctly. Next, If he has tested the ignition, he hasn't informed me of it....so I'd venture to say that he has not. When I say "runs poorly", I mean that it doesn't run at all at times...and other it runs like there are no problems at all? After the engine does die....it is extremely difficult to get cranked again. Personally, I am at a total loss on this one?
