contractor
Thread starter- Joined
- Dec 13, 2005
- 18
Thanks to the two gentlemen that replied. However, each gave a different answer. <br />I have two wiring harness' that come to the console. One goes to the ignition switch, the other to the Suzuki monitor. Each has a yellow wire in it and my engine does not have a pigtail loose that I can hook up to. The harness to the ignition switch also has the grey 12 volt key on hot and the black for the ground.<br />So, if I am to connect to a yellow wire, I have two to choose from.<br />1993 Suzuki DT 115.<br />Any suggestions?<br />
