I can get this 1988 motor to idle only by reducing the idle speed setting, and even then, it idles roughly. It will turn the prop at idle in a tank. However any attempt to speed it up causes it to stall immediately. Even in neutral, any slight opening of the throttle butterfly makes it stall. Compression is good (130-135), but the plugs are wet with gasoline.<br /><br />I have taken the carb apart, and found the main jet completely clogged. Fixed it. Everything else looked good. The float is at the right level, and I ran wires through all orifices.<br /><br />It appears to be running rich, which could cause the idle to be rough. When I open the throttle, I don't know whether it stays too rich or suddenly becomes lean.<br /><br />This leads me to the mysterious Bimetallic Vacuum Switching (BVS) valve system on this motor, which is a starting enrichment system that senses block temperature and sends vacuum signals to the carb. The Seloc manual has a general description, but no real details (I suspect that they don't understand it either).<br /><br />Has anyone experienced this problem? Is the BVS valve in the block bad? Anything else I can look for in the carb?<br /><br />Jack Murphy
