jasonalden
Thread starter- Joined
- Jun 4, 2004
- 89
Well I find myself back in this forum due to a major problem with my engine.<br /><br />I have a 1997 150 Yamaha 2 stroke Saltwater Series II (6 cylinder). Engine model S150TXRV with 426 hours, so it reads (I'm not the original owner; I purchased the boat in June 2004 with about 245 hours on it).<br /><br />Yesterday while out, the engine starts clanking and making just a horrible noise. I immediately put the boat in neutral, and the noise was still present. Then shut it down. When I tried to start it again, the engine wouldn't even turn over. The battery wasn't dead. I dropped the anchor and called for a tow. I pulled the engine cover and the engine was hot, although I don't know if it was abnormally hot, it was just hot. I found a ton of water in the bottom part where the power head is. I tried to crank it, and I saw the starter engage and attempt to turn the flywheel, but once again the flywheel wouldn't turn (just a half inch maybe). Great; it has seized. <br /><br />Well no it hasn't seized because today it WILL turn over. It labors when turning over and maybe after 2 seconds of turning over it seizes. Then, it won't turn over again for about 30 minutes or so.<br /><br />I pulled all 6 spark plugs and the 3 on the port side look good, but the 3 on the starboard side show signs of rust, especially the top 2 (they are really rusty on the spark area of the plugs). All of these plugs were replaced 7/21/04 at 288 hours.<br /><br />What next? Is this a do-it-yourself job or should this be left up to the professional? Are we talking full engine rebuild here (ugggg).<br /><br />Thanks for any help and direction on this issue.<br /><br /> CLICK HERE to view my blog on this problem.
