jasonalden
Thread starter- Joined
- Jun 4, 2004
- 89
Re: Saltwater Intrusion Into 1 or More Cylinders 1997 Yamaha 150 S150TXRV
Rodbolt, referring to the diagram of my eng here <br />Power Head Diagram, can I pull off #15 (the cylinder block/crankcase cover) without removing the flywheel/upper crankshaft hardware (#6,7,8).<br /><br />Also, can I pull off #15 without first removing the carbs? It seems like I should be able to. I don't see a reason to remove the carbs unless you say I have to...<br /><br />Thanks.
