I have the Yamaha fuel management system, which I believe is a 1997 system. That was when the boat was repowered.<br /><br />I believe the pitot tube has fallen off inside. I can easily blow air into the hose, but there is no reading on the speedo. How difficult is it to put this hose back on? I assume I drop the lower unit as if replacing the impeller, right?<br /><br />Also, I would like to use the GPS speed data into the Yamaha fuel management system. Unfortunately, I was told the system has to be a 98 or later. My speedo has a 4-pin connector for the wire adaptor that hooks to the GPS, but my speedo has only 4 jump switches and I was told it had to have 6 switches.<br /><br />Would a 1997 Yamaha speedo have the 4-pin connector? What would be the purpose of that if it can't accept nmea from the GPS?<br /><br />Rodbolt? Ray?
