saltyfeather
Thread starter- Joined
- Aug 28, 2005
- 10
On a past posting there was a mention of a Yamaha Bulletin to fix the issue of making oil on the F115 4 strokes. This included replacing the ECM, thermostats, spark plugs and a new dip stick. Was this work something that should be covered under a warranty? It sounds like a problem Yamaha was aware of and should be correcting at little or no cost. I am being told my making oil issue on my outboard is due to underheating because of a bad thermostat that is not closing. This is causing the rings not to expand for a good cylinder seal and blow by occurs. The issue of a bulletin was discused with the dealer prior to purchasing the boat and they stated they had not haerd of any such bulletin or a fix kit for this problem. <br />What do you guys think ?
