Hi I have what I believe is a 1989 or 1990 200 hp yammaha. The id serial number plate is missing and would like to try and retreave as much info as possible for this engine. It is very simular to the 200etxd ( have picked up info for that one) except the casting numbers an the cylinder block are 6g5-01 and cylinder heads 6g5 02. the 200etxd refers to 6g6 series numbers. I have been told you can find out info from numbers on the block frost plug? (758057). And a 25" shaft. 2.6 l carb. I know this seems like a shot in the dark but maybe someone has gone through this. Thanks
