The boat/motor has been in the shop for a month. The first mechanic replaced the water pump three times but the Suzuke still overheated in the water. The second mechanic (much more knowedgable about the Suzuki) replaced the Thermostat which was excessivly corroded and broken in three parts. Then took the boat for a test drive. Low speed was fine but it overheated at top speed and did not show a notable increase in the tell tail as the RPM's increased. This mechanic suspected a problem and took everything apart. His words were that this 6 year old motor looks like a 20 year old one run in salt all the time. everything had to be scrapped and cleaned. everything had excessive pitting<br />Now the question: <br />What could cause such extreme corrosion in a relativly new motor??<br />Should I and should everyone wash it out with fresh water after each trip?<br />Does this level of corrosion limit the life of the motor? <br />More info about the situation: This year is the first time I replaced the zink. While it had lots of holes it still had its basic shape. I thought it was OK. Most of the time the motor was out of the water after a trip but as the weather turned cold (about a month in the fall) I would often keep the motor in the water to keep from freezing the lower unit. It was rinsed well with fresh water at the end of the year and tarped for the winter. <br />Many thanks for any advice<br />Bob
