I put a stainless prop on my 02 F115 yesterday and took her for a spin to check the rpms and performance, works great! However when I put it into gear now at idle speed the lower unit is making a growling noise. Does it in forward or reverse but as soon as you give it any throttle it goes away. The only thing that has been done to the lower unit was a drive shaft replaced last year because of a scratch on the sealing surface for the lower unit seals. After that I put about 5-6 hours on it with the aluminum prop and no noises. This was the 1st trip this year. Any ideas?
