89 Yam 150 ETLF steering tight?????????????
I have a 1989 Yamaha 150 ETLF outboard. I was doing routine maintainence and decided to add grease. I put grease in two fittings that are underneath the motor against the outside of the transom. I also put some in two fittings on the inside of the transom on the steering assembly (I think). I thought they went to the steering and tilt. Before I started steering was good but now steering is incredibly tight. I used all purpose marine grease. The steering system is called the "no feed-back system" if that helps. Did I use too thick of grease or what? Don't understand how adding grease could make steering tighter unless grease was too thick. Any ideas how to fix???
rodbolt
Re: 89 Yam 150 ETLF steering tight?????????????
did you fully retract the steering cable before greasing?<br /> if not you may have gease in the tube between the cable nut and the cable slidecreating a hydrualic lock.
No, I did not. How would I correct the hydrualic lock now?
rodbolt
remove the cable to tilt tube nut, turn the helm to retract the cable, clean the excess grease from the tube end by the cable nut and reassemble.
Is there anyway you can explain that in more layman's terms? Sorry.
rodbolt
the nut that holds the steering cable to the engine. normally 1 1/8th but can be 1 1/16th. remove it, turn the helm to retract the cable into the steering tube on the engine. pull on the nut end of the cable to get a bit of slack, remove any excess grease.
Thank you for your help. I will give it a try and let you know...Thanks!!!
I tried this and there was not any grease at all. Any other ideas?
Update--there was not any excess grease but I sprayed two cans of WD-40 into the steering tube. The lubricant broke up some built up grease and it seems to be working fine now...I appreciate your help
