Hello..<br />Key to on position..Low oil warning light goes on OK but no overheat light..<br />Tested overheat buzzer by shorting sensors on either / both banks - buzzes everytime.<br />Checked Pink wire... good from buzzer to CDI unit<br />Checked yellow wire... power with key on..<br />Even went and checked oil warning... lift up level sensor on the engine oil tank..buzzer and light OK.<br />Could it be that the CDI unit is not closing the connection for the pink wire?<br />Would the threaded thermositch come into play here at all?<br />Help!<br />Thanks / David<br />(Winspt)
