72INVADER90HP
Thread starter- Joined
- May 6, 2003
- 141
I have a 1987 Suzuki DT 85. Ok hers the problem,<br />With the lower unit on the boat I shift the gear shifter from neutral to reverse and attempted to turn the prop and nothing, in neutral the prop spins both ways. No when I put it in forward gear and attempted to spin the prop I hear a clicking sound and I can turn it by hand. I had the prop looked at and the dealer said it looked fine. So I removed the lower unit and now the shift rod went from neutral to it looks like forward because the rod is in the downward position. And I cannot get to rise back up by hand. If I use a pair of pliers and pull real hard it will go into neutral but it is real hard, and I cannot get it to go into reverse with my hand or pliers. It is like there is a spring that is real stiff. And it will pop out of neutral and back into forward gear. I can take the lower unit apart but what should I be looking for?<br />Thanks for any help.
