Wingnutt
- Joined
- Jul 16, 2003
- 255
Took the project to the lake this evening to check out my handy-work. Got the carb tuned so she idled OK, then took her off the trailer and out into the lake. A pleasant surprise was that I got the balance right after redoing the floor and adding a large casting deck. The only problem was that the engine wouldnt come up to full revs. It sounded like she was only turning about 3500 RPM. Yes I looked down the throat of the carb and the butterfly was wide open. The motor sounded like it was under a heavy load and didnt sound right. Its hard to explain unless youve been around two-strokes a lot, but the motor wouldnt sing the way it should at full RPMs when everything is in tune. Anybody got any suggestions? TIA
