Re: Briggs 5hp Outboard Overspeed Limiter
OK, a lot of bull **** being thrown around here.<br /><br />The Briggs and Stratton engine will never be able to get to 4800 rpm! When in gear at full throttle the best RPM I have ever achieved was 3500 and most of the time it is at 3100rpm at full throttle. At full throttle with the rev limiter disconnected and not in gear I have reached 5000 rpm in short burst. At that speed the engine can literally rip itself apart; something the BS engine can also do when making turns at 2000rpm, idleing (sp) at the dock, or when switching into reverse.<br />I do not know what you mean by shear cone. The propeller has a rubber hub that is designed to absorb shock, I doubt that would ever brake, if it did you would also destroy the propeller.<br />(edit)I am on my 3rd engine. (edit) The engine will work nicely for two months, after that the rev limiter will prevent you from starting.<br /> This OB SHOULD NEVER be placed into reverse until you come to a complete stop, EVEN WHEN DOCKING. The clasp that locks on to the the trim pin, is nearly the size of the pin, if you are moving forward the clasp will miss and it will swing up, brake the engine mount and land nicely with a spinning propeller on your lap. <br />If you guys what to here the whole story, My story with this outboard can take up two whole 48hours shows.<br /><br />P.S I just got my engine back from being in the repair shop for 5 months (they repaired the engine mount) when I got it back it would not start. The timing was off, the idle was not set right and the oil had water in it. It still will not work like it use too. I plan to check the valve clearances tomorrow.
