'75 Wards Sea King 5HP
D Ray
It has a Clinton motor.<br /><br />I can get the motor to run out of the water but can't get it started in the water. It is hard to start out of the water and must be choked to re-start even after it has warmed up. It will fire but won't stay running in the water. The diaphram looks to be in good shape and the float and rest of the carb looks good and clean. Any suggestions as how to get this motor to run in the water under a load?<br /><br />It has no neutral so the prop is turning while starting.<br /><br />thanks in advance.
martinc2
Re: '75 Wards Sea King 5HP
I'm sorry,I don't have an answer to your question. I just bought a Sea King 1975 5hp today and trying to get it running myself. I have no manual and am wondering about gear oil for the bottom end. I don't see a drain or filler plug? What have you learned about yours so far? S/N 1050290 model K500 3108M
thejeepster02
Im not sure if its the same or not. My sea king also started when it wanted too.<br />I found that the gas tank which is mounted on top was somehow deterating and had silvery slime in it causing tempary fuel line clogs.I removed the tank and put some small rocks and carb cleaner in it and shaked the you know what out of it. I did this several times.May not be the best way, but it worked and it may point you to the right direction.
Drowned Rat
jeepster, are you sure that is a Clinton engine you have? I thought Chrysler make Sea Kings in 1975..
thejeepster02
Drowned Rat<br /><br />sorry, I was looking at the response from martinc2, He had the sea king<br />Maybe im full of it. Wasnt it sea king that monkey wards sold years ago?<br /><br />mine could be a 1950's ventage
alcan
Chrysler or West Bend made a 5hp Sea King for Montgomery Ward only one year,1964. Over the years Sea kings were made by several different companies. The most familiar are OMC, Chrysler/W.B., and I believe Eska. Eska used clinton and tecumseh power heads.
PANIC
DRAY, i HAD SAME PROBLEM WITH MY 5HP SEAKING MODEL K055106A, SER 1480621 TYPE XTV50505A. PROBLEM WAS REED VALVES NOT SEATING. THEY FINALY BROKE & I TRIED REPLACING WITH FEELER GUAGE STOCK. wORKED LIKE A CHARM FOR 1 YEAR. NOW I'M SEARCHING FOR COMPLETE REED ASSY OR CORRECT REED VALVE STOCK. GOOD LUCK
D Ray
Thanks to all who replied. <br /><br />martinc2- My motor didn't have a plug on the lower unit either. To add lower unit grease I just took the 4 screws loose off the bottom plate and replaced the old with the new. Some of the old ran out and I scooped out the rest. It was kind of milky so water had been in it. <br /><br />I am looking for a new diaphram for it now. The old on has gotten a little crusty over the last 29 years.
