alittledinghy
- Joined
- May 15, 2003
- 83
on a 1953 7.5 hp Elgin the manual calls for waterproof grease to lube the lower unit. I just opened it up to inspect it and i guess the previous owner drained it before he stored it 20 years ago. The case and gears are oily but grease free and corrosion free and the gears look brand new. What lube should i put in this lower unit ? The shear pin i removed is a rusty piece of steel rod, Was brass used for shear pins on this motor or will the correct size piece of drill rod work ?
