PurpleDragon
- Joined
- Nov 11, 2001
- 124
Hello all,<br /><br />It's been a LOOONG time since I've posted here on iBoats... But it's nearing winter, when I'll have time to do my maintenance & mods on my ole' Sears Boat & 12Hp Sears (West Bend) motor.<br /><br />My pull-starter gear that raises to engage the flywheel to turn start the engine.. unfortunately has a crack in it. I've checked with Discount Marine (Michigan) to see if the nylon gear is available anymore, and unfortunately, it's not... So I'm kind of up a creek without a pull starter.<br /><br />The photo below shows the nylon gear that is cracked. I have a friend who does custom aluminum milling, and was wondering the pros/cons of simply milling a new gear out of aluminum? I realize that teh Nylon gear was made for both lubrication, and to be the "weak link" and that it's better to break a nylon gear tooth on the easily replacable part, than on the flywheel...<br /><br />Thoughts?<br /><br />Anoter option I'm contemplatnig is to simply replace the pull-string mechanism with a starter motor and gear... Anyone know of a supplier that might have a retro-kit or something customizable to my application?<br /><br />Thanks,<br />Rex S.<br /><br /><br />
