1970 Sea King 5 HP engine - info & parts needed
nhsd
Hi,<br /><br />I have a (I believe) 1970 Sea King 5 hp outboard made by Clinton. It is Model #5001106C, Type XTV270Q5B and serial 370535. My dad bought this when I was a kid along with a small aluminum jon boat. It was used for a couple of years and then stored in a basement. I think it has been stored since 1973 or 1974. Well, now I am a grandpa and I would like to refurbish this motor to play with the grand kids. I need some info on where to find parts lists, parts and hopefully a manual. I have my eye on a general outboard service manual (volume I 30 hp and less) but don't know if that will provide sufficient info to identify parts. With it apart it is evident that at a minimum I need at least the following items that are not general items:<br /><br />a contact set<br />a condenser<br />carb gaskets (a carb kit)<br />a diaphram<br /><br />I am not sure what else I will need as I go forth into this adventure so any help or suggestions would be appreciated. BTW supprisingly, to me at least, this engine looks pretty clean. It did start but sputters and backfires. I am doing a good carb cleaning. What do I need to consider about the gearing and lower unit?<br /><br />Thanks for at least reading this far :) <br /><br />Dave Hall
WillyBWright
Re: 1970 Sea King 5 HP engine - info & parts needed
Welcome to iboats.<br />Check the Marine Mega Mall tab above.<br /><br />This site has a wealth of old outboard information...<br /> http://www.discount-marine-parts.com/ <br />Specifically...<br /> http://www.discount-marine-parts.com/ob_clinton.html <br /> http://www.discount-marine-parts.com/ob_sea_king.html <br /> http://www.discount-marine-parts.com/ob_sea_king_clinton_model.html <br /><br />Good luck with it. I have a 7Hp. Check for gearlube, but it's probably a thin whitish grease that won't drain. Check it, but it's probably okay. :)
