oxidation on boat
coachgus
i have 10 year old maroon maxum and it is starting to oxidize--any ideas on the best way to remove it?
tommays
Re: oxidation on boat
if you do a search in the Boat Restoration and Building section its covered in everyway you could think of :) <br /><br />tommays
murphini
Agreed. But, depending on how bad, even going to WalMart (or here at iBoats) and buying some of the off the shelf oxidation remover and a 9" orbital buffer/waxer ($22), you can do amazing work. My red (sparkly) boat was little oxidized/dull and it came out looking like a mirror using a 3m oxidiation remover product. <br /><br />Only bad news is now my wife wants me to make as much effort to make her car as shiny as I do on the boat.
Ian Knox
Originally posted by tommays:<br /> if you do a search in the Boat Restoration and Building section its covered in everyway you could think of :) <br /><br />tommays
HI Tom<br />Real newbie here "search in the Boat Restoration and Building section" - can you help me find that? I need help in doing fibreglass work (enlarging v-berth, glassing in bulkheads) etc.<br />Thanks from Ian, Maple Bay, West Coast, Canada
Gary H NC
I used the product PoliGlow..My boat is red and was very oxidized.It turned out great and the water beads very well.It's not a wax but a fiberglass sealant.Makes keeping the boat clean much easier..
markvan
Collinite No. 920 Liquid Fiberglass Boat Cleaner, works great. Neighbor tried it last year when he was done it looked like he had it repainted
cm5408
like the automotive industry i tried wet sanding my gelcoat. Besides the normal scarryness of sanding a finish, this did wonders!!<br /><br />on areas that had normal oxidation i just used 2000 grit. on areas that were heavily oxidated I started with 800 or 1500 and finished with 2000. Wet sanding removed all of the oxidation, pits, and roughness of the finish. once done, i followed up with a light compound and a buffer. Results were amaizing!! <br /><br />I also read years back about using Floetrol like a wax (rubbing on a 2 x 2 section, letting stand for less that 2 minutes and rubbing off). Though this is a bit of work, the results are like glass and they will last all season. One boats with color in the gelcoat, the color always looks wet, thus the shine!
mattttt25
1. try 3m polish for light oxidation<br />2. try 3m polish for heavy oxidation (definately need buffer for this)<br />3. wet sand- info above is good. i used 1500 and 2000 grit and it's amazing. just have someone clearly explain or show you how to properly do it.<br /><br />start with 1, work down until you get what you want.
