WARDS SEA KING 9.9 - 15?
roadkingman
I AM HAVING LOW SPEED TROUBLE AND LOW IDLE SPEED STALLING ON MY SEA KING MOD# : VWB 52122 / SER# : 58X 3756. TWO QUESTIONS 1) IS THIS AN 85? 2) WHAT PLUGS AND GAP SHOULD I USE? THE OLD OWNER HAS SPLIT FIRE SF409B IN IT. I AM PRETTY SURE THIS IS NOT RIGHT????????
roadkingman
Re: WARDS SEA KING 9.9 - 15?
Found out more info plug should be a NGK B7HS gapped at .30 or a SPLIT FIRE SF409C. VWB 52122 / SER# 58X 3756 makes it a 15 HP 1985 vintage. ANY ADVICE FOR POOR IDLE AND SLOW SPEED PERFORMANCE??
roscoe
Start with cleaning the fuel system, including the carb. Use new fresh gas.
boltdude73
i'm having the same problem, i found that i was running it way to rich. but it still stumbles sometime when i accelarate slowly.
RandyJ
boltdude...if stumbling with slow acceleration you may have either electrical system malfunction or fuel delivery problem...if it has a fuel pump I'd check it... does timing advance as with some outboards? if so, is it doing it properly?
boltdude73
it only stumbles when i try to accelerate slowly, and it does not do it all the time, i've had the carb off and it was spotless, also i found out today that the fitting for the fuel line maybe bad, sucking a little air. she runs very well otherwise, very fast for a little boat.
