alexanderr
Thread starter- Joined
- Aug 9, 2005
- 4
9.9 gamefisher, model 217.586240, serial #08-206426. I do not know the year manufactured.<br /><br />When I check for spark in the plugs by laying them up against a bare spot on the engine with the wire attached, I am not seeing even a weak or intermittant spark, however, when I try to start the engine, it will run poorly for a short while & then stall. So, I am assuming I am at least getting a weak spark because it wouldn't fire unless there was a spark. I bought the engine about a year ago, but got busy doing other things and have not got around to working on it till recently. Prior to even trying to start it, I rebuilt the carb with all the necessary parts that I got from sears, so I am pretty sure that it's not a gas problem unless I have the lean/rich needle totally off the mark. It's hard to tell or adjust the needle if you can't get the motor to run for more that a couple of seconds. I am thinking it must be either the plug transformers and/or the magnito. I cleaned all contacts on the spindle and the magnito but I am still be getting a weak spark. So when I call to get the parts, sears said that the manufacturer was not making these parts anymore. I also tried a number of marine part companies & had no luck. One source,laingsoutboards.com, also said you could not get these part unless you find them used.<br /><br />questions...1.does anyone know where I could get these parts either new or used? 2. can anyone suggest a better way of testing the magnito and the spark plug transformer.
