Re: Ted Williams 7-horse *Propeller doesn't turn..
Sorry, Guess I should of posted the list also<br /><br />Model SEARS 7 HP OUTBOARD MOTOR - 21759440 (GEAR HOUSING ASSEMBLY) <br /><br />WOODRUFF KEY 1 <br /> <br />CLUTCH ASSEMBLY 2 <br /> <br />SET SCREW 3 <br /> <br />DRIVE SHAFT 4 <br /> <br />SPIROL PIN - 7/64 X 21/32 5 <br /> <br />HOUSING - WATER PUMP 6 <br /> <br />IMPELLER 7 <br /> <br />PLATE - WATER PUMP 8 <br /> <br />"O" RING - WATER TUBE 9 <br /> <br />MACHINE SCREW - 12-24X3/4 10 <br /> <br />LOCKWASHER - HI-COLLAR - 12 11 <br /> <br />FLAT WASHER-11/32O.D. X 7/32 I.D. X 1/32 12 <br /> <br />HEX NUT - 3/8-40 CLASS 3 THRD. 13 <br /> <br />FLAT WASHER 14 <br /> <br />VITON SEAL WASHER 15 <br /> <br />WATER TUBE 16 <br /> <br />OIL SEAL - PUMP HOUSING 17 <br /> <br />OIL SEAL - GEAR HOUSING 18 <br /> <br />SLEEVE BUSHING 19 <br /> <br />ROLL PIN 3/32 X 1/2 (STAINLESS STEEL) 20 <br /> <br />"FILL" SCREW - 3/8 - 24X3/8 LON LOK 21 <br /> <br />"FILL" WASHER - RMK 22 <br /> <br />CLIP - STAINLESS STEEL 23 <br /> <br />LOCK WASHER - 5/16 24 <br /> <br />HEX NUT 5/16 - 18 25 <br /> <br />GEAR HOUSING 26 <br /> <br />FLANGE BUSHING 27 <br /> <br />WIRE SNAP RING 28 <br /> <br />PINION GEAR 29 <br /> <br />RETAINER RING - TRU-ARC 5100-43 30 <br /> <br />GASKET 31 <br /> <br />CAP-GEAR HSG. 32 <br /> <br />CAP SCREW-FILL. HD. 12-24X5/8 33 <br /> <br />"VENT" SCREW 34 <br /> <br />WASHER - RMK 35 <br /> <br />BUSHING .379 O.D. X .266 I.D. X 1/4 36 <br /> <br />LOCK WASHER 1/4" 37 <br /><br />CAP SCREW - RD. HD. - 1/4-20X1 3/16 LONGLOK 38 <br /> <br />BRONZE BEARING - FRONT 39 <br /> <br />SHAFT SPACER 40 <br /> <br />BEVEL GEAR 41 <br /> <br />ROLL PIN - OUTER .032 X .156 X .750 42 <br /> <br />ROLL PIN - INNER .022 X .094 X .750 43 <br /> <br />SPACER WASHER - GEAR 7/8 O.D. X .506 I.D. X .023 44 <br /> <br />BRONZE BEARING - REAR 45 <br /> <br />OIL SEAL 46 <br /> <br />WASHER - NYLON 1 1/8 O.D. X 17/32 O.D. X .057 47 <br /> <br />PROPELLER SHAFT 48 <br /> <br />SHEAR PIN 49 <br /> <br />PROPELLER 50 <br /> <br />NUT - PROPELLER 51 <br /> <br />COTTER PIN 3/32 X 1 52 <br /> <br />SHEAR PIN KIT (INCL. (6) 96284 SHEAR PINS AND (1) 6405 COTTER PIN) 53 <br /> <br />GASKET KIT 96498 No Number listed<br /><br /><br />You can order by going to www3.sears.com, enter model number, click continue, then select the "view part list" radio button left of the "Gear Housing Assembly" (2nd from bottom)then it will give you a similar list with a quanity box, add to cart when done and you are done! Sorry about the long post, but to get the info in, you have to do it.
