To get the fore deck to drop at a right angle so the trim work will mate up, I figure add at least three inches. The floor block could probably be fu
West Coast Willy
May 26, 2010
Since all these SCs should be the same, this is the length from last deck seam to anchor wall.
West Coast Willy
May 26, 2010
Need to use your imagination here. Used scrape molding held together by a hot glue gun to form template. Cut inch or so larger, then scribe to wall
West Coast Willy
May 26, 2010
Starboard side trim fit. Notice holes in the salvaged metal. Someone had mounted pole holders and canopy hardware on them.
West Coast Willy
May 26, 2010
X-ray vision again here. This is how it's attached to deck and other is for interior shelf support. Note, had to have enough bow deck to attach 2x2.
West Coast Willy
May 26, 2010
Use your x-ray vision here. I added a piece of 1x4 cedar, leaving the metal half inch longer to account for plywood wall. As will see later, should
West Coast Willy
May 26, 2010
This is view under bow. When I started, my major concern for this area was size to accommodate anchor and rope, not how it would effect the finished
West Coast Willy
May 26, 2010
Port side trim fit.
West Coast Willy
May 26, 2010
Because of that slant, the interior trim angles won't line up. The sides to match the existing trim had to be at 90 degrees so to solve that problem
West Coast Willy
May 26, 2010
Someone said, experience is knowledge gained too late. Well here it is.. By not leaving the fore deck a little longer, the anchor storage panel slan
West Coast Willy
May 26, 2010
Since I've had no experience with the boat in the water I tried to approximate it's plane in the water by lowering trailer. Gives me a better "eye" o
West Coast Willy
May 26, 2010
The object of this album is to address the various issues with the conversion of the bow area. What I discovered along they way and how to make thing
West Coast Willy
May 25, 2010
This is my vision for the Jupiter. Along with the open bow concept, I'm changing it to a fixed four place, tiller operated, fishing boat.
West Coast Willy
May 25, 2010
This is the 1970 Starcraft Jupiter I recently purchased. While it's a fine closed bow boat, I propose to turn it into an open boat.
West Coast Willy
May 25, 2010
Always nice to have faces with projects. This is Netty, aka. Chief Financial Officer, Captains' mate, and I told you so.
West Coast Willy
May 25, 2010
This is my old fishing buddy, 14ft. Valco with 8hp Johnson. Sold it shortly after the purchase of the Starcraft. The "CFO" really liked that!
West Coast Willy
May 25, 2010
This is my fishin' partner Paul and all around good guy, go for, holder oner, what can I do to help dude. He's the one holding the little Chinook. I
West Coast Willy
May 25, 2010
W
70 Starcraft Jupiter Restore/Modification
17
West Coast Willy
May 25, 2010
Album information
Album owner
West Coast Willy
Date created
May 25, 2010
Item count
17
Album privacy
W
West Coast Willy
Media items
50
Albums
2
Can view media items
Everyone
Can add media items
Album owner only
Share this album
