3.0 mercruiser dieseling
Pdevito
I have a brand new mercarb 2 bbl tks. Ive set the idle at approx 725. Why else can cause deiseling. Have not touched factory fuel mixture
725 RPM is too high
have you checked timing?
if all is good with timing after you get the idle within spec, let it idle a bit prior to shutting it off. if you have to pick up a skiier, key off while in gear
Scott06
All above are good suggestions. Would also maybe fatten the idle mix. I decarbonized it by using GM top engine cleaner( others will work as well), seemed to help
need to be careful with the dieseling eng8ne can run backwards and suck water up into it
Pdevito
The tech at the shop said to set idle in gear between 725 and 750. Ive had it as low as 650 until it starts starving while in gear
charliedaubitz1
be sure and check for a vac leak around the carb base. there are several style base gaskets, some don't seal good. A spray bottle filled with water is good to test with.
paulswagelock
Common issue on these motors. When I had mine, letting it idle for a few minutes helped, and shutting it off in gear helped.
JonBoat55
My 1999 carbed Merc 3.0 came to me with a 160 thermostat installed. Had slight dieseling issues and warm start issues for a couple seasons. Eventually swapped it out for a 140 and havnt had any issues since.
Scott06
Certainly anything to get it running cooler, like 140 thermostat or cool down idling will help.
Two other things that helped on mine was running GM top engine cleaner down the carb to remove carbon deposits from the combustion chambers. The top engine cleaner works great, as does sea foam or berrymans. Pour down carb at fast idle eventually stalling the engine let it sit 20 min, then start it. Just dont pour it too fast as you can hydrolock the engine (speaking form experince).
Also try fattening up the idle mix especially if the plugs look lean.
charliedaubitz1
Another thing to consider besides an air leak on the base is, that engine should be run on fuel with no alcohol, it will run lean if using Gasohol.
V6 and All Other Older 4, 6 Cyl & V8 Models, Except Supercharged Models.87 (R+M)/2 Minimum Octane Unleaded Regular or Premium Without Alcohol DO NOT USE Leaded Gasoline
