3.0 mercruiser dieseling
Pdevito
I have a brand new mercarb 2 bbl tks. Ive set the idle at approx 725. Why else can cause deiseling. Have not touched factory fuel mixture
725 RPM is too high
have you checked timing?
if all is good with timing after you get the idle within spec, let it idle a bit prior to shutting it off. if you have to pick up a skiier, key off while in gear
Scott06
All above are good suggestions. Would also maybe fatten the idle mix. I decarbonized it by using GM top engine cleaner( others will work as well), seemed to help
need to be careful with the dieseling eng8ne can run backwards and suck water up into it
Pdevito
The tech at the shop said to set idle in gear between 725 and 750. Ive had it as low as 650 until it starts starving while in gear
If the 3.0 is fuel injected, it will have a 160F thermostat. Carbureted, should be 140 degree thermostat
