Thanks
@jbcurt00 for the heads up…
briangcc, unfortunately with no fix insight the issue is on iboats side and you’re not the only one going through odd times of getting back in because the issue iboats is having is both the inbound and outbound internal email system isn’t currently working so iboats has lost communication with all its members…That mentioned, the only way to fix your original username would be for gaining your trust in any one of your preferred moderators with the/a password you would like to use to regain entrance to the forum as there’s an option inside the admin control panel to input a new password rather we create one for you and let you know what it is or use a new, non used one by you in the past for other personal uses so it’s easier to remember or save? on your side… So far 2 others have gone this route and I suspect there might be a boat load more out there a drift.
Sorry for the inconvenience, but it’s all we got for the meantime.
Please let us know if you’d like to try that option. thanks.
