Vinyl Plank Flooring Installation Decision ???
tpenfield
Greetings,
I am doing a kitchen make-over and will be installing LVP (vinyl plank) flooring. I'm trying to decide the direction to run the flooring and am considering how it would/should look vs. the hardwood flooring in the adjoining room (foyer).
Option # 1 Run it in the same direction
Option #2 run it cross-wise to the foyer flooring
Not sure if there is a 'right' or wrong', but wanted to get some input before I start. I was thinking cross-wise to give it some contrast, but perhaps there is some foot traffic consideration. The flooring will arrive tomorrow. Probably will start laying the floor by the weekend.
southkogs
I like the cross grain look. In some of the older homes I've seen where there different generations of wood, they had a lot of cross patterns like that.
I've heard - don't know how true it is - that a general rule of thumb is to run the grain along the same path as the greatest source of light. So, if you've got a window in there, you may want to look at it with the grain running 90ª to the window glass.
jbcurt00
Run planks direction of the long way room runs, 1st pix
Running across the long way (2nd pix) makes space "feel" smaller/narrow.
Laid thousands of sqft of hardwood plank....
airshot
Opinions are like A$$holes, everyone has one....so do what ever the Misses wants, that is how it will end up anyway.....lol....
tpenfield
After some YT video watching, it appears that the planks should run either the major length of the room, towards a significant source of light (window), or towards a major feature of the room (probably the largest window).
So, it would be option #1. (I had a feeling) :LOL:
tpenfield
The flooring arrived today. It is a bit lighter than the room visualizer pictures, but it will be fine.
I got to finish painting the walls and trim, then get the floor ready for planking. Probably will be working it this weekend.
