1970 6hp Evinrude 6003B Shear pin.
ShootingJack10
I have a ton of Frabill model 2, 16 and 17 packs of shear pins left over from my shop years ago but just restored this motor and wondered if any of these shear pins would work. I know 307949 will fit but since i have all these I was in hope that someone had a chart and could tell me if any of them would fit.
Crosbyman
I just cut myself a few a few weeks ago 3/16 brass rod 1.380 inch long for a refurbed 6Rxx
so if your spare Fabril 2-16-17 are that size they will fit.
jimmbo
Shear Pin? Those Motors used a Stainless Steel Drive Pin, designed not to Shear, as protection from Impacts was provided by other Means
Crosbyman
hubbed prop I guess i'll have to check my prop more closely but personally I prefer brass should I ever hit something .
Correct----Rubber hub.-----A wise fisherman might use a brass pin.----Have 2 brass spares in the tackle box.----And a third spare is the steel pin.
