Re-post of Boomyal's Brined Turkey Recipe!
sangerwaker
Flathead,
Is this just a store bought bird that is frozen? If so, yes, no issue. That's what we use every time we make this brine. Thaw the turkey, brine per recipe, and enjoy. Absolutely delicious smoked with some apple, hickory, and/or pecan. Cook to about 165 to 170 max. The juices just run out when you slice it. Soooo good.
FLATHEAD
Flathead,
Good info, thanks for that.
aspeck
Yes, I like the apple and hickory smoke … 2/3 apple, 1/3 hickory. I pull the bird at about 150-155 …
FLATHEAD
And either here or in the cooking thread can you please post cook details.
Not much to post. Gave it a 12 hour bath in Boomyalls brine. Rinsed it, pat it dry put a little black pepper on it. Smoked at 250/300*. Used a combo of apple wood and a little red oak. No spritzing, no basting just let it go. Not even sure how heavy that bird was, about 10 pounds? Was done in a little over three hours. Was super moist and tasty.
redneck joe
So, all smoke like a smoker or like me with an egg? And what temp internal did you pull off to rest, and lastly did you air dry the bird any?
aspeck
I have never dried the bird … just taken it from the brine to the smoker. I cook at a lower temp for a little longer … a wet smoke … and I use maple syrup instead of the brown sugar …
FLATHEAD
I use an offset smoker and use wood. Pulled it at 165 and let it sit tented with foil for about half hour.
